Rear wheel bearing failure
Old 08-25-2008 | 05:55 PM
Araba Shriner's Avatar
Araba Shriner
Default Rear wheel bearing failure
When I bought this bike, it had chromed HD wheels... My problem is rear wheel bearing failure... twice now. The bike only has 21K miles on it.
I have an HD extended factory warranty, they will replace the rear bearing again, but wont fix the problem of why it is failing. Mechanic says the hub of the wheel must have a problem, but I am told this is not covered under the extended warranty. These are not cheap wheels, and to replace would be a little over $500 just for the wheel.
Anyone have any ideas about this or a cheaper way for me to fix my problem?
Thanks in advance.
Old 08-25-2008 | 06:15 PM
crash1292's Avatar
crash1292
most common cause for a wheel bearing failure is a crushed spacer between the bearings causing a preload on the bearings when the wheel is tightened up.
install 1 bearing and slide the spacer in ...the spacer must stand proud of the lip that the other bearing seats on
Old 08-25-2008 | 06:27 PM
rbabos's Avatar
rbabos
Yup, what he said, plus the press must not be too tight or they will skate, get rough, make heat and basically f up.
A good wrench will look for a cause if it happens twice for no logical reason. First time it's usually chocked up to a bad bearing. Your other post in suspension mentions that you had these parts chromed. Chrome drastically changes critical dimmensions, so that's where I'd be looking.
Ron
Old 08-25-2008 | 06:31 PM
katobird's Avatar
katobird
Hate to say it but
remove the bearing and check to see if the bearing "bore" is a true 90 degrees from the axle.
side load side load side load
Old 08-25-2008 | 08:23 PM
Araba Shriner
Thanks for the great info fellows. The original owner had the chrome wheels installed 2000 miles before I bought it which was around the 13K mark. I was in touch with him today, he still has the stock wheels.
Maybe I should try to talk him into an even trade and put the originals back on.
Old 08-25-2008 | 09:25 PM
Hoffy's Avatar
Hoffy
My rear wheel bearing had a bearing that fell out when the tech pulled my rear wheel at 10,000 miles for a tire replacement. It was the stock bearing with stock wheels.
Old 08-25-2008 | 09:57 PM
Bill03E's Avatar
Bill03E
Take the wheel to a machine shop with the spacer, and axle, have them check the bore of the wheel, and the total width of the spacers, and the wheel.
This would be much cheaper than changing the wheel.
Old 08-25-2008 | 10:02 PM
Bertk's Avatar
Bertk
I would make sure there using the correct "Wheel Installation Kit".
Old 08-28-2008 | 06:15 AM
Araba Shriner
Thanks for all the input... A buddy of mine and I managed to get a look at the problem yesterday. Pulled the rear wheel off, found the problem right away.
There was a ton of play in the spacer between the bearings... Installed new bearings, correct size spacer, no more free play inside the hub.
I cant believe a certified HD Mechanic would put this thing together this way... twice!!!
quiet as a mouse now. hope it stays this way
Old 08-28-2008 | 06:40 AM
rocknrod's Avatar
rocknrod
Of course the guy wouldnt warranty it, he was the problem.
Quick Reply: Rear wheel bearing failure
