Leaking oil from clutch cable adjustment
Old 07-03-2018, 09:59 AM
Payton23c's Avatar
Payton23c
Payton23c is offline
Stage I
Default Help
Originally Posted by Rags722
OK, I can't speak for the 07's & 08's but know my 05 will gather a little crud ( road grime and oil) right where the cable goes in. Not actually a "LEAK" but a tiny bit of oil sweat. No big deal.
However, I have seen a number of complaints on other boards about trans fluid actually leaking out of the ADJUSTER half way up the cable. In every case, this has been traced back to a plugged tranny vent. Keep in mind, wasps and spiders seem to find that dark hole an invitation to build a nest that eventually plugs the vent, and when pressure builds it escapes through the cable.
Rags
I’m having an issue with oil leaking from my adjuster on my 07 Sportster but I can’t seem to find the tranny vent, any help?!?
Old 07-03-2018, 11:51 AM
ORradtech's Avatar
ORradtech
ORradtech is offline
Maybe ask in the Sportster section???
Hundred Dollars
02-14-2012 09:01 AM
skirtbum
06-26-2010 05:45 PM
crewzerdude
04-27-2010 09:18 AM
ski5844
08-15-2007 03:06 PM
Sally88
09-22-2006 11:14 PM
Quick Reply: Leaking oil from clutch cable adjustment
