68 tooth Sportster sprockets on FL's?
Topic is supposed to be FLH's, not just any FL....LOL.
Wondering if anybody has been keeping up with this and what feedback could be provided? Seems to be a direct bolt on but have no confirmation. What it does is move the FL's rear sprocket up 2 teeth from 66 to 68, replicating the '09's.
Any feedback would be appreciated.
OK, what if I said that if you change your stock 66 tooth to a Sportster 68 tooth it will give you 60 more ponies and do the 1/4 mile under 9 seconds, would it change your mind?
Seriously, people are doing this and it is supposed to make our pre-'09 bikes shift like the '09's, would this be a good thing?
Hello? I guess you guys think that putting a Sportster sprocket on your touring bike will cause you to grow a vagina........eh? You should be OK, but stranger things have happened.
pn#40350-04 is the 68 tooth sprocket that will bolt up to the FL's. However, you'll lose your IDS. That's why most are changing out the front to a 30 tooth. Either way you just need to change a sprocket and a belt. Now, the question is will the 68 tooth rear sprocket and new IDS on the 09's retrofit???? That would be pn# 40217-09 SPROCKET & BEARING ASSEMBLY, rear, 68 T
