Difference between Front & Rear Wheels
Old 08-22-2008, 08:22 AM
stukes_md's Avatar
stukes_md
stukes_md is offline
Default Difference between Front & Rear Wheels
I bought a slightly used 9 spoke rear wheel off an '08 Ultra for my RK. In looking at the markings on the wheel, I don't see a H-D part number or any indication that this is a rear wheel. What is the difference between front and rear wheels or are they the same?
Old 08-22-2008, 08:29 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
IRRC, they are not the same--one difference would be the difference in the bolt hole sizes--the pulley bolts are a larger diameter than the holes for attaching the rotor.
Old 08-22-2008, 09:41 AM
hoz88's Avatar
hoz88
hoz88 is offline
I'm not sure the 08 wheel will fit your 07 'king. Didn't they change the spacing for 08?
Old 08-22-2008, 09:46 AM
Zimbob's Avatar
Zimbob
Zimbob is offline
'08 wheels will fit the '07's. I've done it. there is a difference in the axel. change the bearings and you should be good to go.
Old 08-22-2008, 10:02 AM
hoz88's Avatar
hoz88
hoz88 is offline
OK, wasn't sure if the axle/bearing switch would work for him. Good.
Old 08-22-2008, 10:53 AM
blueflht's Avatar
blueflht
blueflht is offline
also need to check the offset of the hub. rear offset for belt and rotor may be different than front
SpaceReapersNOLA
08-24-2016 08:50 AM
Architect
Wheels/Tires
02-19-2014 11:17 AM
ldfry001
03-24-2013 07:02 PM
Milwaukee 1
Wheels/Tires
03-10-2011 12:21 AM
bub 270
02-07-2011 09:09 PM
Quick Reply: Difference between Front & Rear Wheels
