rubber 12 inch antennas $5.98 at Advance
fit perfect, take off all the adapters off the antenna & trash them, or keep them in your goody box
take the set screw off the OEM antenna, and unscrew it
put a little washer on the stub screw on the bike,
and put some medium loc tite on the aftermarket antenna
and run it down till it seats on the washer (you may need 2 washers)
if you monkey fist the antenna on, it will separate at the base, as the stub screw goes too far into the base.
ask me how i know
pics if you need them, they look "right"
ask me how i know
Keep in mind if you use your CB with that antenna you will fry the finals in your radio. It may look better but is not SWR matched to your CB. Cutting the stock antenna will cause the same problems. The new shorty harley antenna's and the J&M's are swr matched to the CB.
