Ultra Classic Seat 08 Upgrade
I had mine done at MCC. I lowered it one inch put the pro pad and 2 inches of foam in the seat. I do not feel any lower on the bike. My *** hurt at 100 miles before now my *** hurts at 200 miles.
So it did get better but now like one said the curve of the seat with extra padding pushes your jewels up.
I will check out Corbin and see if they can custom make me one since I can ride to them.
I do not think the stock seat is wide enough. from what I read for more comfort you need the seat to be wider.
I asked to be lowered 1 inch, ok.
Then I asked for the 2 inches of memory foam and the gel pad, with me so far.
Now there was foam in the seat to begin with, had to be at least 2 or 3 inches stock.
So if I told you to do what I asked above, then I assume you would pull out the old foam and put in the new foam or cut the old foam down until you made the seat 1 inch lower.
But I did not do the work so all I can tell you is I am not 1 inch lower even though you can see the seat is cut down.
