Andrews Gear Drive Cam Set
1 Post
I want more low end torque plus get rid of the chain tensioners. I have A 2004 Ultra Classic with stage II download and filter upgrade running V&H Big SHOT True Duels and Power Commander III. I was almost decided on the 26G but heard I would loose HP. Please Help, Thanks
I have Head-Quarters HQ-0034 bolt in cams in my otherwise stock '04 EG w/Rinehart TD's and SE a/c. The cams really woke up the 88; enough so that I haven't considered a 95, and runs better than the SE BB 95" kits and as well as some street-ported/bolt in cam 95's of my buddies. It has a 36* intake close, while most other bolt in 88 cams have 40* close. My experience seems to confirm the remarks of Joe Minton in the link above regarding better low end torque with an earlier intake close.
Here's a link to BigBoyz cam comparator if you want to check cam timing:
http://www.bigboyzcycles.com/tccams.htm
Good luck with your research.
