No low beams
No low beams
I just did the passing lights on with the high beams procedure
and added an H4ST Silverstar bulb. Every thing worked fine except
now I have no low beam light.
What could the problem be?? I would run with the hi beams on any
way but I`d still like to know what`s wrong.
`04 FLHTC
Thanks..................
`04 FLHTC
Did you cut or unplug the yellow wire that fed the passing lights with power from the low beams or did you connect the yellow wire over to the wire from the aux switch? If you don't cut or unplug the yellow wire the new setup will feed power from the low beam to the high and the high beams will stay on all the time.
`04 FLHTC
`04 FLHTC
joflewbyu2
Electrical/Lighting/Alarm
05-02-2011 02:19 PM
