i assume........
Old 08-15-2008, 06:00 PM
relli's Avatar
relli
relli is offline
Default i assume........
that the battery is dead in my security fob. lights flash and no start. but operates fine with my spare fob. so can i change this battery myself? is there anything to be programmed??anyone know what battery i need???
Old 08-15-2008, 06:03 PM
Chicago Spike's Avatar
Chicago Spike
Chicago Spike is offline
Change your battery once a year, twice if you want to be safe that you won't be stuck. Yes, you can change it, pop the back off and pop in new battery. You don't need to program it, just swap the battery
Old 08-15-2008, 08:08 PM
relli's Avatar
relli
relli is offline
thanks
Old 08-15-2008, 08:16 PM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
Batteries are Us has what you need.
Old 08-15-2008, 08:20 PM
Hog Yild's Avatar
Hog Yild
Hog Yild is offline
Does anyone have the battery number?
Old 08-15-2008, 08:33 PM
tailgater's Avatar
tailgater
tailgater is offline
Panasonic 2032 or equivalent. Positive side down. You can start your Ultra without the fob. Just run the security code using your turn signal switches. You will have to run the code each time you start it but you can ride down to get new batteries-beats walking.
Old 08-15-2008, 09:20 PM
curmudgeon's Avatar
curmudgeon
curmudgeon is offline
Wow, it's been 7 years. I'd better hurry up and change them.
Home Depot sells them. It's the same battery in the garage door opener.
Old 08-16-2008, 04:50 PM
relli's Avatar
relli
relli is offline
too easy. local parts house had em. 3.98 for a pair. switched em both out. thanks again. shudder to think what the dealer charges. LOL
Old 08-16-2008, 07:06 PM
Theakerr's Avatar
Theakerr
Theakerr is offline
Is the problem with locking and unlocking or just unlocking.
Old 08-16-2008, 08:14 PM
relli's Avatar
relli
relli is offline
its with starting or not starting
Quick Reply: i assume........
