Help need answer to shifter rod install.
Bought a new shifter rod with the heim joints on it. recieved free install form
the dealer. Bike seems to shift ok but when you try to rotate the rod there
is no movement at all. Feels like a solid rod from foot shifter to trans there
is no play at all. does this sound normal??
Thanks.
Thanks.
I just installed a shift rod from Kury on my Ultra. It had to be screwed in to it's shortest possible length to match the OEM rod. Add to that, the fact that both ends use right hand threads, even if you turn the shaft it will not change the length. You have to remove one end from the lever and make length adjustments then bolt it back up.
Once length is set, the lock nuts are tightened and there shouldn't be any slack.
Outside.
Outside.
RomeoTango
06-29-2018 02:35 PM
dh_meyer
2014-2023 Touring Models
08-11-2017 09:32 AM
