head light bulb change
You can pull the trim ring by removing the screw in the bottom of it then remove the mounting screws that mount the entire headlight assembly to the fairing, then remove the assembly, change the bulb and put back.
Oh, I forgot, disconnect the battery before service to avoid serious injury or death.
mrthinkshesfunny
02-25-2008 06:22 PM
