You can get the bars and +4 clutch cable from an HD Forum sponsor (Warehouse Direct), they give us a 15% discount. I got bars & cables for $100.22. The Khrome Werks bars are real nice !!
Do you have ABS on your bike and was there any issue with the brake line? Also you mention pulling the passenger side exhaust to change the clutch cable. I guess this would be a good time to do true duals while I am at it!
Yes, I have ABS and the line was long enough. This would be about the tallest bar you could use without changing the upper line. I had already researched and found two places locally that would make a custom length line if needed.
The exhaust has to come off to change the clutch cable.
