Oil change question
Oil change question
My "new" bike has been ridden under 300 miles since mid-2005 and its last oil change. It was changed with Harley Syn3 2050. I have the service records and until it got basically parked, the original owner had it religiously serviced; parts lubed, tightened, new tire and battery and the list goes on.
My question: will oil that old be OK for a 800 mile trip this weekend or does it require changing before I leave? Time is tight, so if I don't have to, I would like to change it when I get back. But I don't want to risk old oil damaging the scoot.
Opinions?
spiz
Opinions?
spiz
If your going on a 800 mile trip on the bike, and it has been sitting for a long time without running. I would change all the fluids (engine oil, trans, and primary). I would also flush out the fuel tank....by draining the old fuel, and then pour in some fresh gas....splash it around in the tank a bit....spill it out, and then fill it with the fuel of your choice. I would REPLACE the battery....or at the very least, remove it from the bike, and take it somewhere and have it load tested. Lube all the cables, check the condition of the tires, and brakes. Make sure your air pressure is set. There are a few other things that you could be done just to be on the safe side, but I cant think of any more right now.
Hitechluddite
Oil Archive (no new posts)
03-22-2009 06:37 PM
