Steering Neck Zerk question
08-12-2008, 10:52 AM
Looking to go to a 90 degree steering neck zerk on my '07 Ultra and was wondering what thread size I'd need to be able to do so.
Thanks
08-12-2008, 11:02 AM
1/4X28npt I believe. I put the 90 degree in and made lubing so easy.
I did mine.
I believe its SAE 1/8" pipe thread.
I just went to Advance auto, they come in a multipack, just make sure you get the one for SAE and not metric.
FWIW, I had to disassemble the 90° to screw it the fitting body in and tehn just put the grease fitting back in the 90.
08-12-2008, 11:17 AM
I thought I read somewhere here that a 45 degree zerk worked better?
08-12-2008, 11:29 AM
Quote:
Originally Posted by
Road Glider
+1 I use 45
08-12-2008, 11:30 AM
yep 45 is easier to install and works like a charm!!
08-12-2008, 11:43 AM
I used the 90 degree fitting on the 06 and the 08 ultra. The thread size i s 1/ 4 x 28 you can get it at any auto store. The first time you fill the neck with grease it will take 1/2 to 2/3 of the tube
08-12-2008, 11:53 AM
Thanks for the fast replies! So 1/4 x 28 and I'll go 45 degrees as well upon the suggestions.
Big thanks. Even our service guys didn't know the thread size.........WTF???
08-12-2008, 12:00 PM
auto supply store for a multipac it will have what you need around 5 $
08-12-2008, 02:21 PM
Did someone say use the HD heavy duty grease?
