Well I did it. How do you remove this crap?
I had that happen on my heritage with the Fatcat pipe.
I used oven cleaner on cool pipes and let it set about 10 minutes, wiped off with a terry towel, I repeated about 3 times and it came off.
someone else mentioned that acetone (or acetone based finger nail polish remover) will melt plastic nylon (makes sense since it melts super glue), but I haven't tried it...not even sure if burnt nylon is still nylon anymore...
good luck...good thing is...worst case youscratch the **** out it and replace the shield
Take a table knife and wrap one layer of a thin washcloth over the blade end. Then use that to remove the larger melted pieces. The washcloth protects the finish of the chrome, but the knife underneath still presents a rigid-enough structure that you can scrape much of it away.
Once the bigger pieces are gone, use Simichrome polish to slowly work off the remaining surface blemishes off the chrome. It's a slow, tedious process so don't start it thinking it's going to be over quickly. A cold brew or two and plenty of patience.
OK>>>OK!!!!
I know I'm late, but once again,,, heres my tip,, NO scratches......
Heat put it there,,, so let HEAT TAKE IT OFF!!! I use one of the bottled propane torches,
like ya use for soldering,,, heat the rubber,plastic, nylon up .wipe with cotton cloth,, about twice, then carb cleaner,, done in about 4 min's!!!!!!
