Fuel Filter Canister Issue?
08-04-2008 | 07:40 AM
RE: Fuel Filter Canister Issue?
found this to be the same for me. \\; Bike takes longer to start since the new canister, but i rarely need to stop cranking and try it again. \\; It is normal for the pump to come on when the bike doesn't start the first time. \\; Starts without issues when hot tho and seems to run the same.
08-04-2008 | 08:48 AM
Mine starts fine first bump
08-04-2008 | 08:49 AM
Maybe the o-ring that seals the shell itself is off a little
or the little o-ring where the regulator sits
08-04-2008 | 08:50 AM
easy to take apart so I'd reassemble and see if it helps
I hate f***n not being able to write a paragraph on here[:@]
08-04-2008 | 09:00 AM
Thanks Dawg, I'll check it out one evening this week.
08-04-2008 | 09:01 AM
Quote:
ORIGINAL: dawg
+1
will check mine at the next checkup! \\; maybe go a head and order new o-rings just to be sure
08-04-2008 | 09:05 AM
Quote:
ORIGINAL: dawg
Dawg you hit it right on the head. My O- ring was not seated properly and I was losing fuel pressure. Once the o-ring was flipped upside down it seated better.
08-04-2008 | 09:33 AM
Which o-ring did you flip, the canister or regulator?
cdavidj
09-01-2015 11:06 AM
swofford92
07-05-2015 12:54 AM
puresportster
06-24-2015 03:28 PM
tphillips
Engine Mechanical Topics
03-10-2014 01:08 PM
Skulls
10-28-2004 02:27 PM
