New Stereo Ordered
Old 08-02-2008 | 08:29 AM
Abnmarine's Avatar
Abnmarine
Default New Stereo Ordered
&nbsp\\;&nbsp\\;&nbsp\\; Yesterday I removed the HD radio, Hogtune amp and speakers. I'll be selling them soon. I have a Sony unit to install with Satellite radio. I ordered two sets of marine Polk Momo MMC 525 5-1/4" 2-way Speakers and a Blaupunkt THA275PNP 75W x 2 Car Amplifier. The amp is small enough to fit inside of the fairing. Should sound pretty good. The amp draw is low on the amp. I'll post pictures of the install along with my new Dakota Digital gauges.
Speakers are 4 ohm and I'll wire them up to run the amp in a 2 ohm load.
Old 08-02-2008 | 11:14 AM
blueflht's Avatar
blueflht
Default RE: New Stereo Ordered
you may want to measure the depth of the top of the radio before buying amp. i beleive you are approx 1.5 to large to fit in fairing. also running 4 ohm speakers in 2 ohm mode may cause overdriving and blow the speakers. try&nbsp\\; infinities kappas if you are set on 2 ohm wiring
Old 08-02-2008 | 11:18 AM
blueflht's Avatar
blueflht
a little more info. the depth for your install is approx 6" plus a rch if you trim the speedo and tach housing. a blaupunkt pa2100 with the housing removed will fit if you can find 1 or a mh instruments amp or a arc audio mini is an excellnet choice. pricey but a very good amp
Old 08-02-2008 | 11:20 AM
blueflht's Avatar
blueflht
more info. if you are running 4 speakerds then you need a 4 channel amp. each speaker is 1 channel. you can run the rear with the head unit and the fronts with the amp. but sound quality suffers. a 4 channel amp pushing 200 watts is 50 watts rms to each speaker as an example
Old 08-02-2008 | 11:26 AM
RoadKingCop's Avatar
RoadKingCop
Making a 4-ohm amp run at 2-ohms will make it run a little hot.&nbsp\\; That normally wouldn't be a problem, but inside a fairing, it may get even warmer.&nbsp\\; Just something to think about.
Ben
Old 08-02-2008 | 12:06 PM
blueflht's Avatar
blueflht
+1 rkc sitting on top of a h/k radio it gets even warmer!
Old 08-02-2008 | 08:13 PM
Abnmarine's Avatar
Abnmarine
ORIGINAL: blueflht
you may want to measure the depth of the top of the radio before buying amp. i beleive you are approx 1.5 to large to fit in fairing. also running 4 ohm speakers in 2 ohm mode may cause overdriving and blow the speakers. try&nbsp\\;\\\\\\; infinities kappas if you are set on 2 ohm wiring
Amp specs are 6-3/4"W x 1-11/16"H x 7-1/4"D. I have 8"W x 2"H x 9"D available. The new Sony head unit freed up some space.
Old 08-03-2008 | 12:02 AM
blueflht's Avatar
blueflht
cant post them here but shoot me an email addy and ill send ypou fotos of my blaupunkt 2100 install with jl audio componets speakers
Old 08-03-2008 | 05:43 AM
Jrsess's Avatar
Jrsess
Let us know how it sounds.
Old 08-03-2008 | 07:41 AM
cmdwolf's Avatar
cmdwolf
I'll take the old stuff off your hands, just PM me when your ready to sell at a good price.&nbsp\\; lol
Quick Reply: New Stereo Ordered
