Problem removing ECU
I was \\;attempting to remove ECU from my '04 Road King Custom so I could install V&\\;H Fuel Pac, only to find that the bolts holding the ECU in place would only spin and not back out.
Anyone run into this problem, and if so, how did you \\;get around it? \\;
I tried to drill a small hole and "pin" the nut in place so I could remove it, but no luck....
Any help is appreciated.
TEXASFIREMAN
21
07-09-2008 07:55 AM
