07 roadking exhaust
Old 07-30-2008 | 03:55 PM
aristoff's Avatar
aristoff
Stage II
Default 07 roadking exhaust
looking for input on removing the factory exhaust and putting on a pair of slip ons, at the dealer they stated that the computer needs upgrading and cost for pipes and aircleaner and upgrade is around 750.00...................................
&nbsp\\;
has anyone done just the pipes and not the rest, if so how does it run,&nbsp\\; I do not have much experience with fuel injection, my last bike was carb and that was easy to adjust.
&nbsp\\;
thanks
&nbsp\\;
Old 07-30-2008 | 04:10 PM
TMART's Avatar
TMART
Default RE: 07 roadking exhaust
On my 07 king,I put rinehart slip-ons and ordered a set of the regular IED's from Nightrider.com and my bike runs great and alot cooler.You really don't need to even do the IED's but for 69.00 dollars it was well worth it.
Old 07-30-2008 | 04:29 PM
Wolfn's Avatar
Wolfn
&nbsp\\;
Python slip ons here....stock air cleaner....O2's should be able to compensate for minor better breathability changing A/F ratio.
&nbsp\\;
IED's??&nbsp\\; I havnt heard of this...what is it?
&nbsp\\;
Old 07-30-2008 | 04:32 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Just SLIP-ONS you should have NO PROBLEMS as long as theyre not Drag Pipes. But dont look for any performance gains or heat reduction with just slip-ons
Old 07-30-2008 | 04:34 PM
SoCal_Pappy
Dont waist your MONEY with a Download as the dealer is required to adjust it to EPA standards and thats LEAN. If your not planning any more then a Basic Stage 1. Go Ness BS and FuelPac
Old 07-30-2008 | 04:36 PM
Northernrider's Avatar
Northernrider
I think the dealer may be wanting to slip you a bologni sandwich. If you're just putting on mufflers you don't need to do anything with the aircleaner or remap. A good set of slip-ons from Reinhardt or V&amp\\; H shouldn't cost you more than $400.
Old 07-30-2008 | 04:38 PM
TMART's Avatar
TMART
They are plug and play inline resistors that go between the O2 connectors that trick the ecm into believing the engine is running leaner than it actually is,therefore the ecm richens it up to compensate for it.The regular IED's are advertized to richen it up from a air fuel ratio of 14.7 to 14.2.The XIED's will take it to 13.8 AFR.This in turn cools the engine a little stops some surging from being so lean from the factory.There are a bunch of threads about it,go to search and type in IED's and you will find out alot more or just go to the Nightrider.com website.
Old 07-30-2008 | 04:39 PM
Northernrider
A good practice is to talk to other bikers before you let the dealer rope you into something you may not necessarily need. Trust your fellow bikers - always.
Old 07-30-2008 | 04:45 PM
2007ELECTRICGLIDE's Avatar
2007ELECTRICGLIDE
I PUT A SEY OF VANCE &amp\\; HINES ON MY 07 ELECTRIC GLIDE AND NOTHING ELSE PUT THEM ON WITH 400 MILES NOW HAVE 12400 MILES AND NOT A PROBLEM LOVE THE BIKE AND THE EXHAUST
Old 07-30-2008 | 04:48 PM
antrome's Avatar
antrome
I installed a set of V&amp\\;H ovals had no problems, other than a little popping during decel.&nbsp\\; I installed a set of Night Rider IED's that seemed to help with the popping.
Quick Reply: 07 roadking exhaust
