HELP!
07-30-2008, 03:28 PM
HELP!
Keep blowing "Aux" fuse. \\; No speedo, tach, turn signals. \\; Can't find short. \\; Ideas??
07-30-2008, 03:29 PM
RE: HELP!
cigarette \\;lighter short?
07-30-2008, 03:48 PM
RE: HELP!
More info... put new fuse in... ok for a bit. \\; Security "key" light comes on. \\; 1st started after hitting a bump on highway.
07-30-2008, 04:12 PM
RE: HELP!
Factory wiring book and a meter. \\; It will be really hard for anyone to troubleshoot your scooter without looking at it. I can give you some tips.
1) Try running one item on the circuit at a time and going for a ride. If you flip something on and it blows…
2) Next, don’t forget to check the out sides of relays as well. You may have no short until the relay is energized.
3) Last, unplug suspected bad parts (if possible) to see if the problem comes back.
07-30-2008, 04:24 PM
RE: HELP!
Yes... been doing all of that. \\; Guess I was just grabbing at straws. \\; Thanks anyway.
07-30-2008, 09:03 PM
RE: HELP!
Any chance that starter relay (pos. 30) could be causing this issue? \\; Would it short that fuse?
08-01-2008, 01:24 PM
RE: HELP!
Update... it was the starter relay!! \\; Phew... another crisis averted!
jonesml
05-16-2015 10:57 PM
eliran
08-17-2014 02:54 PM
Delori
05-01-2013 11:44 AM
CTB
04-07-2008 06:48 PM
Rocks
12-25-2007 06:46 AM
