Help w/HD POI for Zumo 550
RE: Help w/HD POI for Zumo 550
Try this link. I downloaded without registering. I followed the instructions in the manual for my 450 and it worked perfectly.
http://www.poi-factory.com/node/1995
You will have to login to get files. \\; It's in POI files under auto/cycle dealerships on 2nd page. \\; Just got a Zumo 450 so not an expert. \\; If you haven't already, you need to install POI loader from Garmin to install POI. \\; Lot's of good info at POI.com.
Good luck.
Good luck.
The most up to date list will be the one by Dave817. That fileis copied by most other sites but his updated version usually shows up on Gpspassio.con first.
http://www.gpspassion.com/forumsen/t...TOPIC_ID=56474
