Tour pak question
Tour pak question
I have a laydown license plate and currently mt pak is off. \\; I do not have the quick detach kit, it is hard mounted.
Do you know if the stock license plate mount supports the pak? \\; Will it be ok with out the stock Plate mount?
I don't want to hit a hard bump here on these wonderful Missouri roads, NOT, and have something crack or fall off.
Thanks
Thanks
RE: Tour pak question
On the stock Ultra and EG Classic, the plate that the license plate mounts to IS the rear structural support for the tourpak.
Warden, I assume that what you have done, is remove your tourpak, removed the mounting hardware, and replaced the it with a laydown license plate? And what your asking is, if you wish to put the tour pak back on, using the STOCK mounting hardware, will you have to remove the laydown license plate and go back to the stock one.
YES.
The only way to use the laydown plate and mount your tourpak, is to use the quick detach mount. The quick detach mount does NOT use the license plate as a structural member.
In a nutshell,
Quick detach, you can keep your laydown plate
Original hard mount, you MUST use the original license plate braket.
ORIGINAL: Bluerose
No the license does not support the tour pack. You will have to relocate the spring that holds the passenger intercom connector in its slot .
Guest
Posts: n/a
ORIGINAL: Warden
I have a laydown license plate and currently mt pak is off. \\;\\\\\\; I do not have the quick detach kit, it is hard mounted.
Do you know if the stock license plate mount supports the pak? \\;\\\\\\; Will it be ok with out the stock Plate mount?
Thanks
Thanks
I hear that (greetings from Tom Sauk Mtn.)
Ride Safe
