RPM vs MPH
Old 07-24-2008 | 10:47 AM
bagman1's Avatar
bagman1
Default RE: RPM vs MPH
Now that I have a 103 kit and International frt sprocket (-2 teeth) in 6th at 3k-3100 is a perfect minimum w/o lugging Im at 81-82 mph, otherwise 70-75 in 5th at about 34-3500 (but she sounds good there)
Old 07-24-2008 | 11:44 AM
garyhendley's Avatar
garyhendley
+1 on the sound and feel-ride safe
Old 07-24-2008 | 12:43 PM
crackercap's Avatar
crackercap
ditto&nbsp\\;to that, shift by feel and ear, works everytime
Old 07-24-2008 | 12:59 PM
FLHT's Avatar
FLHT
ORIGINAL: SoCal_Pappy
6th over 70MPH
Learn to shift by listening to the Engine. Youll know When its right to shift.
BINGO!
Old 07-24-2008 | 01:17 PM
RoadKing_Al's Avatar
RoadKing_Al
RPM &amp\\; MPH have nothing to do with when you shift. It's all about load (the total weight) &amp\\; incline or decline (which all effect the gross load). IF the bike &amp\\; you only weighed a 100 lbs (a hypothetical weight) you could probably start off in 4th gear instead of 1st (but we don't).
So you should go by the sound of the engine. I do. Drove a semi for years and never used the tach. Tachs are for racing in my opinion.
JJAA's Avatar
JJAA
ORIGINAL: glens
Here is an image of a spreadsheet I have. I typically shift at 20, 30, 40, 50, and 60. No lugging whatsoever, but I have freer-flowing airbox and mufflers along with appropriate fueling.
&nbsp\\;
Glens,
Can you publish you Excel file ?
Thanks,
JJ
Old 07-24-2008 | 04:28 PM
glens's Avatar
glens
My shift points are by feel/sound.
I have uploaded this before but will try today again.
Drop the .txt from the filename and you will have a zip file.
Old 07-24-2008 | 04:32 PM
JJAA's Avatar
JJAA
Thanks. Downloading does nor work at present time.&nbsp\\;[:@][:@][:@]
I'll try again, again, again.
Old 07-24-2008 | 04:37 PM
glens's Avatar
glens
Maybe the search system will allow you to find one of the posts where I uploaded it about a year ago.
Old 07-24-2008 | 04:43 PM
Red Hot Ultra's Avatar
Red Hot Ultra
You should always rely on the sound. Too many veriables to consider, grade, weight, passengers... engine sound is a guarentee
Quick Reply: RPM vs MPH
