Arnott Air Shocks a week later
RE: Arnott Air Shocks a week later
ORIGINAL: assassin307
Even in the fully lowered position?
ORIGINAL: BadX
The shocks are the 13 in Bilstein which wont let you bottom out against the fender with a 18 inch wheel on the back
Correct. \\; I've riden it all the way down, its a little stiff but looks awesome that low going down the road.
ORIGINAL: BadX
Correct. \\;\\\\\\; I've riden it all the way down, its a little stiff but looks awesome that low going down the road.
ORIGINAL: BadX
I bet, great info, thanks! \\; Just one more question, how many inches from stock is it lowered when the shocks are fully lowered? \\; I have the stock shocks on mine now with a 1 inch lowering block. \\; Im wondering if the Arnotts will lower it even further?
Thanks again for all the help!
John
I bet, great info, thanks! \\;\\\\\\; Just one more question, how many inches from stock is it lowered when the shocks are fully lowered? \\;\\\\\\; I have the stock shocks on mine now with a 1 inch lowering block. \\;\\\\\\; Im wondering if the Arnotts will lower it even further?
John
ORIGINAL: BadX
Correct. \\;\\\\\\;\\\\\\\\\\\\\\; I've riden it all the way down, its a little stiff but looks awesome that low going down the road.
ORIGINAL: BadX
John
10 or 10.25, I cant remember off hand which and I think the stocks are 12 so you would only be gaining a inch lower but the ability to raise it so you don't scrape which with the extended bags I want all the clearance I get going through the twistys
