Last week my Voltage on my 05 Ultra went down to 10V's. this happened two years ago &\\; I replaced the Regulator. I haven't had a problem since then. I replaced it again &\\; today my wife &\\; I were riding to work &\\; the voltage droped again to 10V's. Also the chack engine lite came on &\\; the code read PO113 Which is IAT Sensor voltage open/high EFI. Did I get a bad Regulator &\\; why did the PO 113 come Up can Anyone help me. I will check the voltage at the stator lator on this afternoon &\\; also the readings @ the regulator. All suggestions are alway helpfull.
Did you check the output of the alternator?? There were some problems with the rotor wearing through/shorting the wires from the stator on some twin cams.
I'm going to check the Altenator output, &\\; the Regulator later today. I will also check the condition of the battery. the heat out here in The Chandler Az. area seems to play hell on your electronics.
