Headlight Trim
Headlight Trim
I am fairly competent, and have a service manual, but can't for the life of me get that trim ring on. \\; The manual show no orientation of the springs. \\; Mine all popped out when the ring finally came off. \\; I have got the side ones on, but the top spring I assume is the same way locked in correct? \\; Also, \\;the hook is offset to the left slightly (when looking at the headlight), to match in the galvanized housing correct. \\; Anybody got a secret on this? \\; I had less trouble installing cruise control. \\; Maybe its the lack of sleep. \\; Thanks for any help.
RE: Headlight Trim
Try this thread it will explain what to do...Also you will need a lot of four letter words and patience...Jer \\; \\; https://www.hdforums.com/m_1725166/tm.htm
