Thundermax help
Thundermax help
Quick question. \\;\\\\\\; I have Map #524 loaded in right now. \\;\\\\\\; What is the "easy" way to manipulate the AFR vs TPS@ rpm tables. \\;\\\\\\; Is there a copy paste feature that I am missing, or is it the change each dot individually? \\;\\\\\\; Just checking..........
Also, anyone getting backfire on high rev de-cel? \\; To lean? \\; To rich? \\; ect ect..........
RE: Thundermax help
Change the map you want and then Shift Ctrl and C. Any other maps you want it copied to , open the map, left click on the map and then Shift Ctrl and V. 524 basic settings has the decel feature off as default. Change the 0 to 1 and play with the upper and lower decel values until you're happy.
Ron
Ron
RE: Thundermax help
i was getting alot of decel pop till i changed maps im supposed to run map 393 rh true duals and i sitched to map 403 and i get no decel pop and i dont use the decel eliminator you will need to change final drive ratio and speedo cal to match your bike but if its a 96 motor it will work for you also. i think the pop is in the timing.
Mathews2
06-22-2008 08:55 PM
