Going to do a 4000 mile oil change Chicago heavy traffic at times gears clunk, louder when hot. is Amsoil 20w 50 in all 3 holes recommended. Also is changing the trans fluid with the oil recommended or is it overkill. Thanks
i run amsoil 20-50 for oil and primary the 75-90 severe gear in the tranny found it to be smoother shifting. \\; manual says 20k for tranny on my 08 but did it at 5k anyways.
I run AMSOIL in all 3 holes. Have been for many years on many Putts. Change out Engine oil every 5K and Trans 10K. In heavy traffic ALL THE TIME as I live in So Calif.
WHy not change your fluids based on their condition rather than an arbitrary schedule? For example your primary will be cleaner/dirtier based on how much shifting you do (traffic or highway) and whether you are a clutch-slider (which most of us do a little more if we ride with a passenger or in hilly conditions). I guess to keep it simple and to have an external reminder mileage is an OK tool but there are other ways.[:-]
I did my own 5 k and my indy recommended amsoil 20w50 for the engine 10x40 or maybe it was 10w30 i can verify that for the primary and amsoil gear lube for the tranny (cant remember the number) works fine.
Dave
