oil pressure reading
07-17-2008, 11:26 PM
I have a 2004 twin cam stock flht ulta. \\; with 26,000 miles what should my oil pressure be at idale and running when hot?
07-18-2008, 03:19 AM
RE: oil pressure reading
 \\; \\; \\; \\; No reason it should be much off from new I would think..
07-18-2008, 04:35 AM
my 07 is normal at apprx 10 idle and 30 running
07-18-2008, 04:41 AM
+1 Same on my 07
07-18-2008, 05:24 AM
Agree on the 07
07-18-2008, 06:15 AM
These engines dont require a high oil pressure. Like everyone said.....about 10PSI at idle.....and about 30PSI as your riding is sufficient and normal.
07-18-2008, 06:26 AM
Most all Harley motors are roller bearing motors,and you cannot build a lot of pressure on this style bottom end.10 and 30 lbs is right. \\;
07-18-2008, 02:55 PM
For my 2002 FLHRI would the same numbers apply? \\; I'm thinking about getting the Arlen Ness Oil Pressure Gauge.
Tom
07-18-2008, 06:49 PM
 \\;My 2004 Electra Glide manual says 5 PSI at idle when warm.
07-18-2008, 07:01 PM
my 2006 rg is about 10 when idled-ride safe
