Question about Tach for Roadking
Old 07-17-2008 | 09:19 PM
lkman111's Avatar
lkman111
Default Question about Tach for Roadking
I have a 1997 FLHR-I and I was told that because it has EFI that I can not put a tach on it, I saw a great factory Roadking tach on EBay and did not bid on it because it may not work.&nbsp\\; Any help would be great, I know that Ultra's have a tach and they came out in 97 with EFI.
&nbsp\\;
Lakeman
Old 07-17-2008 | 09:49 PM
chuck2000RK's Avatar
chuck2000RK
Default RE: Question about Tach for Roadking
great question i want a tach also
Old 07-17-2008 | 10:29 PM
itileman's Avatar
itileman
The mini tachs are in the 08 catalog. Only no-fit I saw was if you have a windshield bag. Don't see that FI would make any difference. The combination speedo/tach is for 07.
Old 07-17-2008 | 11:31 PM
roadkingsaddlebrooke's Avatar
I had one of the minitachs(purchad from Zanotti)&nbsp\\;installed on my '08 FLHR\\; dealer charged two hours.&nbsp\\; I had them do it because the instructions made the job look a little difficult.
&nbsp\\;
Old 07-17-2008 | 11:46 PM
JefFLH's Avatar
JefFLH
My '05 Road King Police came with one from the factory. Don't see why it wouldn't work for you. It connects inside the headlight nacelle.
Jeff
Old 07-18-2008 | 12:28 AM
Medicfrost's Avatar
Medicfrost
Whoever told you that is full of BS. &nbsp\\;Here's a 97 EFI&nbsp\\;for sale with a mini tach:
&nbsp\\;
http://seattle.craigslist.org/see/mcy/757767876.html&nbsp\\;
&nbsp\\;
The description has the part number for the tach he used.
Old 07-18-2008 | 06:25 AM
BigDaddyMike's Avatar
BigDaddyMike
My 05 has efi and my HD mini tach works great. I had a mount custom made for it so I could mount it about the speedo and not interfere with my detachable fairing
&nbsp\\;
Old 07-18-2008 | 07:22 AM
Dennydp's Avatar
Dennydp
My 97 RK has had a HD tach installed since day 1.Works great
Old 07-18-2008 | 08:19 AM
roadkingrick's Avatar
roadkingrick
whoever told you that is full of ****,&nbsp\\; mine has one.
Old 07-18-2008 | 08:27 AM
miacycles's Avatar
miacycles
In order for MOST aftermarket tachs to work you need either a pink wire or a pin in the speedometer plug (usually # 3 pin). If not then you are probably stuck with a combination tach. We are trying to get a mini-tach to work on an '04 EFI softail. We even tried using Dyna's tach adapter with out any luck. I am sure that a top end tach would probably work, but the less expensive mini's can give you problems.
Quick Reply: Question about Tach for Roadking
