front brakes
RE: front brakes
you may have air in the system and it needs to be bled. If your pads were low and you never added fluid as the the piston had to travel more to apply the brakes, you may have somehow got air in there, did anyone accidently hit the brake lever when there was no wheel on it?
RE: front brakes
..I just experienced the same problem on my 2001 RK. The book calls for dot 5 fluid which I used to no avail. I replaced the master cylinder and flushed and used dot 4 fluid and all is well now. Your other option may be to have the system flushed with a power bleeder to get any trapped air out. Good luck!
RE: front brakes
ORIGINAL: Janster
RE: front brakes
Check this forum. \\; It worked perfectly for me - https://www.hdforums.com/m_1965292/tm.htm
RE: front brakes
Although its on a forum it is nothing but other peoples opinion, not science or fact. Ive been a cert mechanic for 30 yrs. I never heard that nor would I suggest doing that. 2 things you dont **** with or skimp on unless one knows what they are doing especially on someone elses vehicle is steering and brakes. That my friends can be a deadly mistake
RE: front brakes
bagman, I agree, it's not good to mess with the brakes unless you know what you are doing. \\; My brakes were so bad that one piston on each side of my front brakes was not moving at all. \\; I cleaned the pistons with good brake cleaner and a soft toothbrush, and it worked perfectly. \\; Take bagman's advice... it can be a deadly mistake. \\; I will, however, say that it did fix my problem 100%.
