Sattelite radio direct connect problem?
Old 07-12-2008 | 09:47 PM
bigdaddy405's Avatar
bigdaddy405
Default Sattelite radio direct connect problem?
Can I hook up a fairly new Sirius Stratus radio direct to 12v or should I just use the cig lighter adapter?
Old 07-12-2008 | 10:14 PM
gman's Avatar
gman
Default RE: Sattelite radio direct connect problem?
look at the DC power cord that came with it.&nbsp\\; I have a Sirius Starmate, and the cord indicated it was reducing the voltage down to less than 5 volts.&nbsp\\; I added a power receptacle under the fairing and secured the DC cord to it.&nbsp\\; think if you go to cyclegadgets.com or other vendors, you might be able to find a cord that has a voltage reducer built in that you can then direct hard wire.&nbsp\\; If not and your cord does step the voltage down, you'll have to do what I did or something similar using the factory cord.
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
Old 07-12-2008 | 10:58 PM
bigdaddy405
Thanks for the reply, I will check out some sites.&nbsp\\; Mine has to sit in the dock to work.
Old 07-13-2008 | 08:05 AM
gman's Avatar
gman
mine has to sit in the dock also.&nbsp\\;\\\\\\; the cord i'm refering to is the power cord from the dock to the power source.&nbsp\\;\\\\\\; check the other end of it, it will usually indicate what power is required and what power is outputed to the dock.
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
&nbsp\\;
Old 07-13-2008 | 08:15 AM
spirit80's Avatar
spirit80
I just order this mount from Sirius,
&nbsp\\;
http://shop.sirius.com/edealinv/serv...\;oldParentID=
&nbsp\\;
SIRIUS Professional Motorcycle Install Kit
Model#: SIR-PMK1
&nbsp\\;
I will let you know Tuesday when it comes in.
&nbsp\\;
&nbsp\\;
cirhere2
07-04-2008 08:06 PM
gadgetman
Gear and Other Items For Sale
07-03-2008 11:40 AM
electaRICK
06-23-2008 07:35 PM
swaite
Motorcycles For Sale
13
06-23-2008 12:32 PM
Quick Reply: Sattelite radio direct connect problem?
