Not flat footed on ground. What to do?
Old 07-12-2008, 10:27 PM
67riv's Avatar
67riv
67riv is offline
Default RE: Not flat footed on ground. What to do?
First go to your salesperson tell them you should get a 20% discount on some parts because he did not bother fitting you to your bike.&nbsp\\;Try Profile low touring shocksa reach seat&amp\\; a good pair of thick soled shoes. If that does not work then go with the blocks nailed to your shoes&nbsp\\;
Old 07-12-2008, 10:36 PM
SportoKing's Avatar
SportoKing
SportoKing is offline
Stage II
The Reach seat is a good option. It it drops the seat height about 1/2" and moves you forward about the same.&nbsp\\;\\\\\\; It also allows your legs to be closer together, which helps more than I thought it would.&nbsp\\;\\\\\\; They also have a lowering kit for the RK that lowers the bike 2". I did both on mine and have not noticed any negative aspects of the ride.&nbsp\\;\\\\\\;
Ride safe
Old 07-12-2008, 10:47 PM
GVTHNKS's Avatar
GVTHNKS
GVTHNKS is offline
I was in a similiar situation, but good riding boots and just getting used to it made all the difference to me.&nbsp\\; I have ridden others with lowered suspensions and modded or reach seats. &nbsp\\; lowering compromises suspension travel. &nbsp\\; Seats work well with little ill side effects so long as you're comfortable.
Old 07-12-2008, 10:58 PM
Cue's Avatar
Cue
Cue is offline
sportoking,
Do you ride two up with your lowering kit and what was the name of it?&nbsp\\; I am not a novice bike rider, but this RK is a big step up from the honda shadow spirit 750 I traded it for.
Thanks cue
Old 07-12-2008, 11:06 PM
Cue's Avatar
Cue
Cue is offline
I am willing to change the seat,&nbsp\\; what would be the best option?&nbsp\\; Buy an aftermarket seat or send the seat to mean city cycles.&nbsp\\; I want what is most comfortable and achieves my goal.
Thanks for all the input.
Old 07-12-2008, 11:35 PM
Glyde's Avatar
Glyde
Glyde is offline
New seat is your best- and least expensive- option.
Old 07-13-2008, 01:07 AM
hwyjunkie's Avatar
hwyjunkie
hwyjunkie is offline
Hey Guy
&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&n bsp\\;&nbsp\\;&nbsp\\;&nbsp\\; Check these guys out. I had the same problem and they rebuilt my shocks for me. What a difference in my stance and the bike handles great. http://bitchinbaggers.com/
Old 07-13-2008, 01:26 AM
BaldEagleou812's Avatar
BaldEagleou812
BaldEagleou812 is offline
Seat would be the first and foremost. In a combo to that would be an extended heel boot.
Old 07-13-2008, 02:37 AM
drrandall1's Avatar
drrandall1
drrandall1 is offline
www.bitchnstitcninc.com
&nbsp\\;
before
after
&nbsp\\;
before
after
&nbsp\\;
at work
&nbsp\\;
Trust me. The best $225 I ever spent
Old 07-13-2008, 03:55 AM
drfeelgood's Avatar
drfeelgood
drfeelgood is offline
Stiletto's... for your wife.&nbsp\\;\\\\\\; I guess.
Quick Reply: Not flat footed on ground. What to do?
