07-08 V&H True Duals fit 06 SG?
Old 07-12-2008, 12:24 PM
achog88's Avatar
achog88
achog88 is offline
Default 07-08 V&H True Duals fit 06 SG?
I thinking about installing ThunderMax/Autotune on my 06 SG.&nbsp\\; Since it requires exhaust with O2 sensor bungs, I was wondering if the 07-08 V&amp\\;H True Duals will fit the 06.&nbsp\\; Has anyone tried it?&nbsp\\;&nbsp\\;Were there any fitment issues?&nbsp\\; I have read that V&amp\\;H True Duals' O2 bung on the left&nbsp\\;pipe may need to be moved in order to fit the longer O2 wide range sensor of the Tmax, any experience with that issue?&nbsp\\; Thanks for your feedback.
Old 07-12-2008, 03:50 PM
blueflht's Avatar
blueflht
blueflht is offline
Default RE: 07-08 V&H True Duals fit 06 SG?
if you already have a set just drill a hole in the back header weld a nut and instsall the o2 sensor
Old 07-13-2008, 03:50 PM
achog88's Avatar
achog88
achog88 is offline
ORIGINAL: blueflht
I only have stock pipe with V&amp\\;H Oval.&nbsp\\; I am thinking of getting some kind of true daul that has O2 sensor bungs build in so I don't have to do any drilling and welding for the Tmax/Autotune.&nbsp\\; Any suggestion or experience on similar setup?
Rumbles
01-18-2014 04:52 PM
cmashark
10-19-2013 11:47 PM
hythomasf
05-13-2012 04:38 PM
strich
Exhaust System Topics
04-08-2009 09:54 AM
07HDRKC
12-15-2007 03:43 PM
Quick Reply: 07-08 V&H True Duals fit 06 SG?
