PCIII Map Question
PCIII Map Question
Hello yet again! \\; lol
I have an 08 Street Glide with stock motor and ECU. \\; I installed an Arlen Ness Stage 1 Big Sucker and Python Slip-Ons. \\; I loaded the "canned" map (M818-006) from the Power Commander website for ths setup. \\; The bike runs great, good power and pickup. \\; My only problem is that my gass mileage sucks now. \\; I barely get 30mpg. \\; Does anyone have any suggestions on how to improve this? \\; \\;Better yet, Does anyone have a "tweaked" map they care to share?
I bought the PCIII and Ness big Sucker from Fuel Moto. \\; Great guys by the way. \\; They provided me with a map for my setup but it was running even richer than the Power Commander map. \\; I was getting a lot of gurgling when I closed the throttle and the pickup was a little sluggish. \\; That is what prompted me to try the Power COmmander "canned" map.
Thanks for any help,
Willie
Willie
RE: PCIII Map Question
How much did you ride the bike with either or both the exhaust and airbox on it before you put the PC-III on?
Because, if you did, your AFVs went higher than 100% and you locked them into place when you put the O2 eliminators on. If that's the case, you need to reset your AFVs. Either at a shop with a Digital Technician or by putting your stock breathing stuff back on and riding normally for a half-hour or so. The plug-in reset would be the surest thing to do to get them at 100% again. They might end up somewhere just a tad high or low by riding with the stock gear on.
High AFVs will make the bike run rich everywhere.
I had the same problem with canned map. I had run just mufflers beforehand. It was too rich everywhere, would not pull past 90 in fifth. Studied up on AFV, put stock parts back on, took a couple-hour road-trip. Put all new stuff back on at once. All is good now. 38-42 mpg again.
