Windshield/Fairing Pucker
Old 07-10-2008, 07:08 PM
BillinNY's Avatar
BillinNY
BillinNY is offline
Default Windshield/Fairing Pucker
I bought an inexpensive windshield, came flat and you have to curve it to install.&nbsp\\; Well, the three screws on the fairing snug right up, but its leaving a pucker or small gap between the two outer screws and the middle screw on my '08 FLHT.&nbsp\\; I'm concerned water may leak into the fairing.&nbsp\\; Is this just a consequence of this type windshield or can I do something to fix it?
&nbsp\\;
Thanks for any and all replies,
-Bill-
Old 07-10-2008, 07:15 PM
MDodson's Avatar
MDodson
MDodson is offline
Default RE: Windshield/Fairing Pucker
The cheaper windshield may be thinner. I put some weather stripping on mine
Old 07-10-2008, 08:34 PM
Fletch's Avatar
Fletch
Fletch is offline
Is there any room for movement in the W/S holes? If so, you could try tightening the center screw first and then working the curve into the shield as you tighten the outside ones. Otherwise, I'd go with the weather strip idea.
Old 07-10-2008, 08:59 PM
RAMP27's Avatar
RAMP27
RAMP27 is offline
6th Gear
The area under the outer fairing is completely exposed to the elements. Water leaks down between the windshield and fairings on OEM units all the time. The gap is probably more a cosmetic problem than anything else.
Old 07-11-2008, 11:47 AM
Peppa1's Avatar
Peppa1
Peppa1 is offline
www.clearviewshields.com
Nuff said !!!![sm=smiley20.gif]
Old 07-11-2008, 11:58 AM
Bossman1's Avatar
Bossman1
Bossman1 is offline
The operative word being Inexpensive.
Never had any luck with UNITEDFITSALL!!!
Old 07-11-2008, 12:16 PM
Magos's Avatar
Magos
Magos is offline
Yeah, I bought one of those cheapies from ebay and it did the same thing.&nbsp\\; I have entertained using a heat gun to mold it a bit more but I just put the stock one back on for now.&nbsp\\;
Take their advice and go with a clearview that is premolded.
Old 07-11-2008, 12:22 PM
FLHT's Avatar
FLHT
FLHT is offline
I bought a couple of the cheap flat windshields but only to figure out what height I wanted and then I bought a quality windshield.
EasternSP
2014-2023 Touring Models
17
09-30-2017 04:02 PM
leftyjm
08-17-2016 06:22 PM
oakmossy
11-22-2014 10:27 AM
kc10boom
09-30-2008 09:06 PM
bob53
10-24-2006 10:37 AM
Quick Reply: Windshield/Fairing Pucker
