The stage 1 and syn oil lowered the heat on mine. I also changed the pipes which helped a bit more. Or, you could save it for the winter time. In February that heat feels pretty good.
I HAVE AN 02 ULTRA/SIDECAR THAT I JUST BOUGHT &\\; THE HEAT IS A REAL ISSUE - SEEMS TO BE ALOT OF GOOD ADVICE HERE - THE HEAT SHIELDS KEEP THE HEAT DOWN, I UNDERSTAND THAT - BUT I WANT TO GET THE TEMP DOWN - IN WHAT ORDER SHOULD I START MAKING THE MODS MENTIONED ABOVE UNTIL I HAVE THE BIKE OPERATING AT MORE COMFORTABLE TEMPS - THE STEALER SAYS THE SIDE CAR WEIGHT CAUSES THE EXTREME HEAT, BUT THE ONLY THING THEY RECOMMENDED WAS AN OILER COOLER??? - ADVICE APPRECIATED
electrarick - they have u pegged correctly "class clown" - but also unhelpful &\\; not funny - \\;sorry to see that your a fellow new yorker \\;- but now i can see why we get a bad rap! \\; \\;
