Are stock left & right mufflers the same
RE: Are stock left & right mufflers the same
Not sure I understand the question, but if you check your bike stock you will find most of the exhaust coming out of only one of the pipes (can't remember but I think it is the right pipe). \\; I think part of the deal with TD's is both pipes breathe better. \\; I put Bub7's on mine and it is a great sound and seems to run much better (did a bunch of other things, too, so I cannot attribute the improvement to any one thing.)
Heat is way down on mine and we built it up to a 107. \\; A good tune with the SERT, TD crossover helps with the perceived or real torque loss and RJs heat shields. It's much better. \\; The sound on the Bub7TD with Crossover is mild when you go easy and when you are cruising. \\; If you want to burn fuel and make it bark you can.
