EITMS
Guest
Posts: n/a
Guest
Posts: n/a
RE: EITMS
Oops found it: https://www.hdforums.com/m_2973953/tm.htm
Looks like mine does not have it or the Stage 1 download killed it. \\; (My bike \\;was built \\;Sept 07)
RE: EITMS
Asked my dealer about this. On the early build dates it can't be self activated. It has to be done by them. If you have the SERT you can do it yourself with ver 4.7.7. There is a check box in the tuning tables. Only problem is if you custom map and don't have a copy, you will over write it when you reprogram the ECM.
Mathews2
06-22-2008 08:55 PM
