Removing Stock Seat Bolts
Old 07-08-2008, 04:28 PM
kct001's Avatar
kct001
kct001 is offline
2nd Gear
Default Removing Stock Seat Bolts
Does anyone know how to remove the stock seat bolts that come up through the rear fender?&nbsp\\; I am not sure if they are simply held on by the white plastic washers or if you have to go under the fender to remove.&nbsp\\; I am in the process of putting a badlander seat on instead of the stock one.&nbsp\\; Your help is appreciated.
Old 07-08-2008, 04:31 PM
mslater741's Avatar
mslater741
mslater741 is offline
Default RE: Removing Stock Seat Bolts
just pull the washers off, and push them down
Old 07-08-2008, 04:36 PM
blueflht's Avatar
blueflht
blueflht is offline
just remember the bolt on 1 side also hold the tube for your wiring harness
Old 07-08-2008, 04:38 PM
kct001's Avatar
kct001
kct001 is offline
2nd Gear
Does that mean that pulling the washers and pushing the bolts down will compromise the rear wiring harness?&nbsp\\; Do I need to drop the rear wheel and take a look at it or is it something simple?
Old 07-08-2008, 04:41 PM
blueflht's Avatar
blueflht
blueflht is offline
the harness may drop down and rub. if you have a stand lift bike and shine a lite at front of the wheel to see the harness tube. you may need to drop the rear shock bolts for a good view. also you shouldnt need to remove them for the seat . it goes rite over them
Old 07-08-2008, 04:44 PM
kct001's Avatar
kct001
kct001 is offline
2nd Gear
Not removing the seat bolts at all would be ideal as I may want to switch back and forth between seats depending on the riding I am doing.&nbsp\\; Are you sure that the Badlander seat will fit over the bolts without removing?
Old 07-08-2008, 04:46 PM
e6fmf's Avatar
e6fmf
e6fmf is offline
I have done the same. I suggest for safety you remove the rear tire go get a good view and access to the harness. After you remove the seat bolts, caulk and duct tape will hold the harness in place to the inner side of the fender. Re install tire.
blueflht's Avatar
blueflht
blueflht is offline
every seat i have ever used went over the bolts. stock harleys mustang and corbins. wouldnt take but a minute at the dealer to drop yours and but a badlander on. sit on it see if you like it. imho mustang is the only way to go
Old 07-08-2008, 05:06 PM
blueflht's Avatar
blueflht
blueflht is offline
just did a quick search on ebay and here. badlanders all over dont know the yr of your bike but plenty seats avial. fgor about 125$
Old 07-08-2008, 06:06 PM
bigskyhd's Avatar
bigskyhd
bigskyhd is offline
I think that badlander will fit right over the top of those bolts.&nbsp\\; My Corbin Stinger, and Corbin Dual Tourer do.&nbsp\\; I'd try that BEFORE pulling the wheel.
Quick Reply: Removing Stock Seat Bolts
