It is the marathon me880 size 130/90 and recommends 50 psi on the sidewall
If you keep it inflated at 50 psi you should get good service out of the tire. \\; I think the problems encountered by a lot of people is that they try to run the lower pressures recommended by Dunlop, and cause their tire to wear prematurely, or worse, come apart. \\; I love my Metzlers, get every bit as much milage as Dunlops, and enjoy their superior handling and wet weather performance. \\; I run 50 psi in the rears and have never had a problem.
