Lowered my E Glide and have some questions for others...
Old 07-11-2008 | 06:59 AM
Curt J's Avatar
Curt J
Default RE: Lowered my E Glide and have some questions for others...
Go to this thread in general Harley chat and you may think twice about lowering your bike at all. Stupid idea!!!
mudd corner eats a harley on the dragon (pics)
Old 07-11-2008 | 07:14 AM
Danowert's Avatar
Danowert
ORIGINAL: Curt J
&nbsp\\;
Must&nbsp\\;be a lot of stupid people out there then. Try looking a little closer at the pictures.&nbsp\\; If you are that far over in your lean angle you better expect problems.&nbsp\\; It sure did not help that he was doing "the wave". More occupied looking "cool" than making the turn.&nbsp\\; There is not much of a problem riding out a lowside unless you jerk the bike. Just look at how the bike continued to track around the corner. the "wannabe' off'd the bike not the other way around. Dumb **** "RUB wannabe" probably went home and had the wife tell him he was selling the bike or no more nookie.
&nbsp\\;
Keep your criticisms to yourself. I'm asking for personal experiences from people who have lowered their bikes, not subjectibve opinions&nbsp\\;from people who obviously haven't. Read the text.&nbsp\\;The bike is already lowered so how can I not lower it?
Old 07-11-2008 | 07:40 AM
Curt J's Avatar
Curt J
Raise it!!!! Just because other people are doing it doesn't make it a "good thing to do". It is very common in the "RUB Wannabe" circle to lower bikes.
Old 07-11-2008 | 10:12 AM
blueflht's Avatar
blueflht
i have a different suggestion for you. take your 12" shocks and remove the air valve. put them upside down in a press and compress shocks fully removing the 5 wt oil. then spin the shocks and extend them adding 7.5 /10 synthetic shock oil. this will increase the damping effect of the shocks allowing you to run this angled setup without bottoming. there is another thread here that a fellow did with great results. total cost 12 $ for oil and about 2 hrs labor and beer! the 5 wt oil is to light and allows shocks to bottom. hope this helps
Old 07-11-2008 | 11:18 AM
Danowert's Avatar
Danowert
Thanks Blue. I added more air (using SG chart instead of the EG chart in the manual&nbsp\\;now) and it definitely helps and its not bottoming out nearly as bad, but yours seems to be a better final result.&nbsp\\; I'll pull&nbsp\\;them apart as soon as get oil. I have a buddy at Penske Racing down in NC and he used to work in the racing shock division on the World of Outlaws circuit a few years back.. To be honest he said straight out that the shocks could definitely be retuned and that would help.&nbsp\\; How much he wasn't sure. He said to ask around and see if anyone else would have a mechanical solution.
&nbsp\\;
Thanks again Blue for the positive advise.
pattiann
01-08-2010 03:18 PM
easy4me
08-18-2009 09:32 AM
wwb
07-21-2008 08:26 AM
atrox88
06-30-2008 01:44 PM
lpitman
06-21-2008 12:43 AM
Quick Reply: Lowered my E Glide and have some questions for others...
