Dyna Beads Tire Balancing
Old 07-07-2008, 09:52 PM
tslonige's Avatar
tslonige
tslonige is offline
Default Dyna Beads Tire Balancing
I put them in my tires today, the ride is smooth as glass.&nbsp\\; I was looking for something other than weights for my FatSpokes.&nbsp\\; These are definately the answer, especially if you change your own tires.
Old 07-08-2008, 08:45 AM
vette's Avatar
vette
vette is offline
Default RE: Dyna Beads Tire Balancing
Good info Thanks
Old 07-08-2008, 10:58 AM
rocknrod's Avatar
rocknrod
rocknrod is offline
How is it installed on mounted tires?
Old 07-08-2008, 11:07 AM
jbhawley's Avatar
jbhawley
jbhawley is offline
check the dyna beads web site or bike web world online for the procedure.&nbsp\\; They come with an application bottle. Remove the valve stem and slowly pour the beads into the tire.
Baffler1's Avatar
Baffler1
Baffler1 is offline
&nbsp\\;- HOW ABOUT A PIC???&nbsp\\;&nbsp\\;&nbsp\\;
Old 07-08-2008, 08:34 PM
WVULTRA's Avatar
WVULTRA
WVULTRA is offline
ORIGINAL: tslonige
I put them in my tires today, the ride is smooth as glass.&nbsp\\;\\\\\\; I was looking for something other than weights for my FatSpokes.&nbsp\\;\\\\\\; These are definately the answer, especially if you change your own tires.
&nbsp\\;
+1!&nbsp\\; Same here!
&nbsp\\;
[sm=icon_cheers.gif]
Old 07-08-2008, 08:54 PM
Wassup8687's Avatar
Wassup8687
Wassup8687 is offline
I've been reading alot of good stuff about them. Seems they are pretty popular. Anyone know if dealers are using them instead of the weights?
Old 07-08-2008, 09:12 PM
Mathews2's Avatar
Mathews2
Mathews2 is offline
Put a commader on the back of my SG today and installed the beads. just wondering if i should put them in the front lop or change it to a commander then put them in.
Old 07-08-2008, 10:37 PM
tslonige's Avatar
tslonige
tslonige is offline
Put them in when you change your tire out if there isn't much mileage left on it, other wise go for it now.&nbsp\\; I keep 4 extra bags on hand, 2 bikes, and carry them if traveling.&nbsp\\; There is a little bottle with a plastic tube attached.&nbsp\\; You remove the valve stem and pour the beads in.&nbsp\\; It takes a little patience if you just have stock valve stems.&nbsp\\; If you order there stems, very easy.&nbsp\\; They will go in either way. It ensures a balanced tire always, no lost weights, poor spin balance, etc\\;&nbsp\\;&nbsp\\;Safe riding. www.innovativebalancing.com
Old 07-09-2008, 12:06 AM
Mississippi Bagger's Avatar
Mississippi Bagger
Mississippi Bagger is offline
Been using these for the last 18k miles or so.&nbsp\\; Big difference.&nbsp\\; Really like them.
Quick Reply: Dyna Beads Tire Balancing
