removing Corbin Solo Seat
RE: removing Corbin Solo Seat
I concur, give the key a crank with one hand, and lift the front of the seat (right where it joins the tank) with the other. \\; \\; When you remove it, you'll notice that there is a sliding/closing piece of metal underneath the seat \\;that keeps it fastened to the front seat post (that pyramid looking post you mounted to the bike). \\; \\;
I had the same issue. \\; As long as the key is turned the locking mechanism is unlocked. \\; The seat is hung up on the metal piece that attaches to rear fender. \\; It is somewhat adjustable and seems to be pushed too far forward. \\; Go ahead and yank it up from the rear with the key turned \\;and u'll be good to go. \\; Then adjust the fender mount bracket further back so as to eliminate this from happening again. \\; Good luck. \\;
edizzle
05-14-2013 09:33 PM
