PCIII Map for 08 SG
PCIII Map for 08 SG
Hello,
Back in February I bought a Arlen Ness Stage 1 Big Sucker and PCIII from Fuelmoto. \\; The PCIII came with a Fuelmoto map and works flawlessly. \\; I am about to add \\;a set of Python Slip-Ons to the mix and I was wondering if anyone has a PCIII map for this setup?
I emailed Fuelmoto and they did send me back a map but it is just named M818-Slipons2. \\; When I open the map up there is nothing in the notes section. \\; Wondering if this is the correct map for my setup or just a generic one for a Stage 1 Setup with Slip-Ons? \\; \\;I also downloaded a map (M818-006) from the Power Commander website. \\; When I compare the two maps they are quite different. \\; I'm just wondering if anyone has any idea which would be the better map? \\; Even better, does anyone have a map that for this setup that works well, or one that they have tweaked?
Once again thanks for any help,
Willie
Willie
RE: PCIII Map for 08 SG
ORIGINAL: bpd138
Hello,
Back in February I bought a Arlen Ness Stage 1 Big Sucker and PCIII from Fuelmoto. \\;\\\\\\;\\\\\\\\\\\\\\; The PCIII came with a Fuelmoto map and works flawlessly. \\;\\\\\\;\\\\\\\\\\\\\\; I am about to add \\;\\\\\\;\\\\\\\\\\\\\\;a set of Python Slip-Ons to the mix and I was wondering if anyone has a PCIII map for this setup?
I emailed Fuelmoto and they did send me back a map but it is just named M818-Slipons2. \\;\\\\\\;\\\\\\\\\\\\\\; When I open the map up there is nothing in the notes section. \\;\\\\\\;\\\\\\\\\\\\\\; Wondering if this is the correct map for my setup or just a generic one for a Stage 1 Setup with Slip-Ons? \\;\\\\\\;\\\\\\\\\\\\\\; \\;\\\\\\;\ \\\\\\\\\\\\\;I also downloaded a map (M818-006) from the Power Commander website. \\;\\\\\\;\\\\\\\\\\\\\\; When I compare the two maps they are quite different. \\;\\\\\\;\\\\\\\\\\\\\\; I'm just wondering if anyone has any idea which would be the better map? \\;\\\\\\;\\\\\\\\\\\\\\; Even better, does anyone have a map that for this setup that works well, or one that they have tweaked?
Willie
Hello,
Willie
I think SOME good stuff happens at FuelMoto, but if you don't have exactly the set-up that is their favorite thing to sell at the moment you get less than what you might have been told you would get and expected. Like a custom map specifically for your set-up.
Doesn't sound like that happened.
ORIGINAL: oldhippie
