Garmin power question?
Old 07-04-2008 | 01:44 AM
greg09997's Avatar
greg09997
Default RE: Garmin power question?
The center post of the cig lighter is Pos. Connect your pos, there and you can share the same gound as the cig lighter.
Old 07-04-2008 | 06:04 AM
Jinks's Avatar
Jinks
The spare leads on the headlight circuit &amp\\; the cigarette lighter are the same circuit. Just plug two spade tips into the leads right behind your headlight, it's switched &amp\\; works just fine.
Old 07-04-2008 | 09:11 AM
rocknrod's Avatar
rocknrod
ORIGINAL: streeter
your Garmin GPS runs on&nbsp\\;\\\\\\;just under 5 volts, hence the electrical gadgets in the male socket. Leave the socket in place and hard wire in under the fairing a lighter socket to plug into. Just a thought.
Okay lets review.
So I wire in a female cig lighter socket to the headlight spades?
Or do I cut the cig socket off the Garmin power lead and wire it in?
Thanks guys
Old 07-04-2008 | 09:18 AM
Badfinger's Avatar
Badfinger
Either way will work.&nbsp\\;I like the cigarette lighter and the lights don't have to be on to work it. It switches off with the ignition and wont run down your battery if you forget. I just stripped&nbsp\\;off about a quarter inch of insulation about an inch from the back of the lighter and soldiered my wires on.&nbsp\\;You can slip some shrink tubing over the wire first to protect it or just tape them. &nbsp\\;I don't know about the other method.
Old 07-04-2008 | 09:29 AM
1hd08EGC's Avatar
1hd08EGC
+1 on the marine grade cigarette lighter. Easy on and off. Adding tunes to the Zumo today for my trip this weekend.
JRay
Old 07-04-2008 | 10:40 PM
bsps1111's Avatar
bsps1111
From the Garmin website I ordered a replacement power cable (find your gps and look under accessories) and had my dealer connect it to the acc switch.&nbsp\\; The connector exits the fairing with the handlebar and is elastic banded to the bar with&nbsp\\;an excess 6 to 8 inches in the fairing.&nbsp\\; I simply pull the connector to the gps when it is mounted and push it back into the fairing when not needed.
ZOSO
Electrical/Lighting/Alarm
05-04-2014 10:29 AM
butch50
04-28-2012 11:03 PM
sanlyn
07-27-2011 11:37 PM
alandchris
01-18-2009 07:22 AM
capt42a
03-30-2007 07:13 AM
Quick Reply: Garmin power question?
