When you went to a 21" front wheel, what did you do to your fender?
RE: When you went to a 21" front wheel, what did you do to your fender?
first tape 2 washers to the inside of the fender, \\;mount the tire and wheel and make sure it doesn't rub, if it does, take the fender off, drill out the back holes on each side and **** the fender forward. drill out the holes 1/8" works every time
Every bike is different, on mine when I mounted the 21, I couldn't even spin the tire because it was rubbing. \\; I taped a nut to the tire, and drilled out the rear mounting holes tipping the fender forward till it cleared.
[IMG]local://upfiles/13020/C66A2B802F7146858DBA719B1FC28CF3.jpg[/IMG]
RE: When you went to a 21"\\\\\\; front wheel, what did you do to your fender?
I had the same experience as Flyboy, only I couldn't get the rear fender holes hogged out enought to clear, so I welded in a set of Native Custom Baggers brackets. All is good now.
Every bike is different!
Zach
Zach
