Turn Signal Trim Rings: Question?
Old 07-02-2008 | 09:15 AM
08HD's Avatar
08HD
Default Turn Signal Trim Rings: Question?
Kit # 69740-01
Directions show only installing (1) lens screw. It appears that the lower lens screw along with the ring screw and nut is the only fasteners to use with one screw that use to go in the top on lens left uninstalled. Am I correct in doing this? Just want to make sure I see what I think I see.[sm=confused06.gif]
Old 07-02-2008 | 09:46 AM
BlkSilverado's Avatar
BlkSilverado
Default RE: Turn Signal Trim Rings: Question?
I've installed the trim rings on a friends bike, but just put them on, didn't remove or loosen the lens screws.&nbsp\\; You'd think the upper screw missing would let water into the housing. Guess I should have read the instructions...&nbsp\\; LOL
Old 07-02-2008 | 09:55 AM
russl179's Avatar
russl179
You need to at least loosen the lenses in order to place that thin rubber o-ring on. Also, you need enough space between the lense and the housing so that the trim can slip in. You really need to stretch the trim in order to get it completely over the lense. I used both lense screws.
Old 07-02-2008 | 10:47 AM
rounder999's Avatar
rounder999
Yes use both
Old 07-02-2008 | 12:27 PM
08HD's Avatar
08HD
leaving a hole in the upper lens will let water in. It is amazing that the directions are not as detailed as it should be to avoid uncertainty. Ok, I will use both screws from the lens. What I did was follow the instructions which had me remove the lens totally.
Now I will:
[ol][*]replace lens and loosen slightly to allow trim to be applied with rubber o-ring[*]tighten trim[/ol]Which isn't according to instructions but seems more logical. I am learning not to follow instructions which is a new learning process
Old 07-02-2008 | 12:36 PM
bigskyhd's Avatar
bigskyhd
If the instructions don't appear to make sense, then use the school method....Think through it, what would Daddy do, and is it going to leak, rattle, or come loose?&nbsp\\; The old noodle is usually best for these easy ones. &nbsp\\;
ShockwaveTXB
07-01-2013 10:19 PM
Memo7070
04-05-2012 01:49 PM
Badbagger
02-19-2011 12:42 PM
offshoreo
09-10-2010 04:56 PM
Dustmaker
12-19-2008 02:30 PM
