Feulmoto pak install
Thinking about installing the stage one kit with power commander from Fuelmoto. Wondering about how hard and complicated a job it is. I'm pretty handy with tools just don't want to screw up any motor stuff!! I read it's not bad and would like to save the HD store labor costs.
RE: Feulmoto pak install
ORIGINAL: Stretglyd08
Your map may not be off in and of itself. If you have been running with aftermarket mufflers, pipes, or airbox, then your AFVs are what are off. If you have been running that way, you need to reset them (easiest way is to have a dealer do it with their Digital Technician).
I had the same problem after running Rush 2-inch mufflers before installing the PC-III and K&N airbox (both from Fuelmoto). After reseting my AFVs the map was pretty darn close. Before, it was so off that I could not accelerate past 90 in 5th.
