Did my oil filter cause this?
Old 07-01-2008 | 05:28 AM
pococj's Avatar
pococj
Default RE: Did my oil filter cause this?
ORIGINAL: garyhendley
i agree with pococj must have been a defective filter
While I offered that up as a possibility, I do not think it was the cause.
Reason being there was apparently no top end noise.
Believe me, if you have even a temporary loss of oil pressure, the top end of your engine will sound like it is coming apart!
Old 07-01-2008 | 06:26 AM
Coolhawg6622's Avatar
Coolhawg6622
I have been running this filter on my last 3 bikes for tens of thousands of miles......Wix is 5 times the filter as the harley (champion) filters!!!......You may have got a bad one but it has a bypass in it if it wasnt working properly so you wouldnt loose pressure.....I would not hesitate to put one on anything I own.......
Old 07-01-2008 | 10:18 PM
glens's Avatar
glens
(This was supposed to be posted last night but problems with the site prevented it, I fell asleep, then I was gone all day. I see another response similarly suggests some of the following)
It could not possibly have been the particular tank of gas? If the filter was not working properly it was either flowing too freely or not freely-enough. One would cause low pressure to develop at the gauge and probably too little time anywhere to pick up heat as much heat. The other would cause both higher-indicated pressure and temperature, right? I am going back with the gas on this one instead.
firehawk6
02-14-2018 05:40 AM
kylebryan
05-01-2016 12:10 PM
hillcountryflt
07-08-2013 08:55 AM
Detroit Sparky
08-26-2009 01:09 AM
roadking1327
Oil Archive (no new posts)
14
04-02-2007 05:30 PM
Quick Reply: Did my oil filter cause this?
